rear axle 7.5/8.8 interchangable?
Old 06-07-2011, 08:54 PM
wbsterritt's Avatar
wbsterritt
wbsterritt is offline
I recently picked up a salvaged rear axle which is identical to the one I'm replacing except the ring gear is an 8.8 instead of the original 7.5. Question is; what adverse affects, if any, am I up against? Will it simply be a difference in the speed indicated or some other issues also?
Old 06-07-2011, 10:38 PM
Southern Bronco's Avatar
Southern Bronco
Southern Bronco is offline
If they are the same gear ratio then no problems, if not then just the speedometer will be off. Other than that you shouldn't have any problems.
Old 06-08-2011, 03:29 AM
michigan66's Avatar
michigan66
michigan66 is offline
If the gear ratios are different, you still can do the axle swap. You can get the correct speedometer drive gear from a Ford dealer or at shop that services speedometers.
