Pros and cons srw vs drw! Trying to pick!
I have had both and now I have a DWR and it feels much better towing as most will admit but it is a pain trying to park at some places. I dont mind a little walk so I will just park out in the lot a little further out. I have 4:10;s and get a little over 17 mpg but I also have the 6 speed.
whoever says you need a bigger parking LOT for a dually needs some serious driving lessons! lol... for the kind of use you are looking to use your truck for i would get a dually. the extra 2 tires is not that big of a deal. and not to mention the COOL factor! wide hipped ladies rule the road!
Duallys all the way. You get to park under the loading zone at Home Depot and Lowes. You get front row parking at Menards.
The absolutely best feature about having a dually is when some A-Hole thinks he can park a foot over the parking line or at an angle cuz he is the parking lot god. You get to pull into your stall legal and legit and that S.O.B. is Fkd and has to crawl in from the other way. You know you feel good when you get to do this to that person
Thats when I push them out of the way with my truck. I get to park there cause you know, Im a big truck, and I'm on the clock and I'm gonna be loading up building supplies, not garden pots.
Received 3,657 Likes
on
The F350 doesn't require stops at weigh stations unless you are hauling for commercial purposes. Its under the 26k GCWR therefore, unless the load is for commercial purposes, doesn't have to stop, this a common misconception though.
Depending on the state, yes a dually will be subject to commercial plates. At the tolls, you'll be charged as a commercial 2 axle +trailer. Make sure you check your local laws on the license you'll need with the new truck, but I think you'll be fine with a regular DL.
In CA all pickups have commercial registration. That doesnt mean its a CDL vehicle obviously, just registered as a commercial vehicle. Strangely enough that includes vehicles like El Caminos because technically they have a bed, and on their registration it says "TRUCK"...
You can register a truck as non-commercial if you put a shell on the bed though.
As far as weigh stations here, if your GVWR is less than 26,000lbs you do not have to stop. However, all box vans regardless of GVWR has to stop, including UHAULS.. *ahem...*
Do they have signs posted that pickups must stop, because the Fed DOT doesn't require it. Must be the state has an interest in it, thanks for the heads up.
Commercial plates on a 1-ton pickup DO NOT mean you must stop at a weigh station...I drive all over the state of Arizona (as well as many other states) on a regular basis and I have a CDL. Heck, if one-tons had to pass through the weigh stations the line would go back out into the highway...a lot of one-tons in Arizona. They can require any vehicle to pull in, but a 1-ton pickup is not required to pull in unless it is being used for commercial purposes. In fact, I can never remember seeing a 1-ton in a weigh station in all my years of driving, anywhere!
ive got a dually as well....4.10 gears and manual trans. So far this summer i have gotten just over 16 mpg around town (see mods below). it is my DD so it can be a pain some times running around town but it is SOOO stable pulling the camper. 36' bumper pull and no sway. even in cross winds and passing 18 wheelers....its solid. The unloaded driving is a bit rough....there are some bumps on my way to work that i really hate going over.
You pay more up front for the 6 tires, but if you tow or haul a lot, the tires on a dually will last a lot longer than they will on a single. On the tire cost over several sets the advantage will go to the dually in a big way.
A disadvantage is they are less capable running empty in snow, at least that's my experience.
Hey bud, you going to rre? I'm heading to Anderson Sunday afternoon when leaving rre. Maybe we could meet up. If your going we could convoy back. Pm me.
In la I drive a 4500 dodge all over with no cdl or tags. Only prob I have is driving to tx with a trailer. But as far as my personal truck I've never had any problems! Could be just lucky!
#28
I agree with the snow claim...if I didn't have four wheel drive...I wouldn't have gotten to work a few times this past winter, but with it locked I had no problem zipping along at 65 on the parkway in 8" of un plowed mush, the real bummer is the locking rear axle....useless in 2wd, with even a light dusting...I vote dually if u can find one not beat to death
#29
#30
