lets see some high boys with 37s on them - Ford Truck Enthusiasts Forums
Old 06-05-2011, 09:03 PM
ben8892002
ben8892002 is offline
ben8892002 is starting off with a positive reputation.
I just got a set of 37x12.50-16.5 goodyear wrangler mts on military double bead locks. Wheels are wrong backspacing im wondering what you guys have found. Mine is a 1974 highboy stock springs no lift. Thanks
Old 06-05-2011, 09:49 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
PA74F250 is gaining momentum as a positive member of FTE.
For those tires I like just using the factory steel wheels off the highboy. That's what I did. If you do a search for hummer tires you'll see what mine looks like with them on. As long as the wheel is like a centerline offset and like 6-8 inches wide that's perfect. A 10" wide wheel is too much makes them hard to blow up and also u end up with a shorter tire.
Old 06-05-2011, 09:52 PM
ben8892002
I thought about my stock wheels ill search it and check yours out thanks alot pa 74 f250
Old 06-05-2011, 10:00 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
No problem. If you can't find it let me know I'll post them again.
Old 06-06-2011, 12:21 AM
Kyle 4X4 4life's Avatar
Kyle 4X4 4life
Kyle 4X4 4life is offline
Kyle 4X4 4life is starting off with a positive reputation.
Heres my 75 highboy, 3" lift and technically it has 38.5" boggers, but they are worn down to about 37's.lol
Old 06-06-2011, 07:18 AM
ben8892002
My boggers on my looked like that when I sold them. Lol
Old 06-06-2011, 07:19 AM
ben8892002
Sorry on my jeep
Old 06-06-2011, 02:03 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
They should work on the rear, and you will have to get the front rims re-centered in order to use them. They are hitting your tie ends right?
Ck around with a local 4x4 shop they should have a idea who can do it for you. Or just get you some aftermarket 16.5 rims.
Old 06-06-2011, 02:06 PM
ben8892002
the right front clears everything but the left front sidewall hits the hydraulic assist in the steering. i will probably mount them on my factory steelies tonight.
Old 06-06-2011, 02:08 PM
ben8892002
i like pa74f250s set up with the stock steel wheels but the 12 bolt double beadlocks would be sweet.
77&79F250's Avatar
77&79F250
Used OEM parts guy
Old 06-06-2011, 02:11 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Getting 2 of those rime re-centered is not that big of a deal, it gets done all the time. Alot of rock crawlers use that set up, cheap rim and tire combo.
Old 06-06-2011, 09:32 PM
Kyle 4X4 4life
If i could get enough cash i'd get me new ones...but im broke so im running bald.lol
Keithwaits
2017+ Super Duty
28
11-03-2016 07:49 AM
55 dude
1947 and Older Ford Trucks
07-19-2016 10:57 PM
seabass152
6.7L Power Stroke Diesel
27
01-13-2016 02:54 AM
37justford
12-05-2014 06:04 PM
josejuan
05-25-2010 02:46 PM
Quick Reply: lets see some high boys with 37s on them
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
