trying to ID Ford manual Transmission
I just bought a 300 6 cyl and mated to it is a transmission that I believe is a manual 3 spd. I am trying to ID it so I can figure out what to do with it. I dont need the tranny it was th 300 engine that I need as the block is cracked in my 75 F250.
What I know about this transmission is this.
Casting on the side says 'ORION'
tag riveted to the side has two lines, top line 'PABJ' and bottom line has 'DGJC2507' stammped on it.
I have been searching with these numbers to no avail. Does anyone know what this tranny might be?
If it's just a regular 3-speed it would have a 9-bolt top cover that can be removed. It could be the 3.03 3-speed tranny. It is also referred to as the 3-speed "toploader" transmission. Does it have external linkage for the shifter? If so, does the linkage connect to two bolts on the outside of the trans?
4601ton
09-14-2017 09:19 PM
Fordf15081
09-29-2016 11:41 AM
hillcountryflt
01-23-2015 02:51 PM
KrautBurner
08-13-2011 12:58 PM
mikeinri
11-24-2006 11:52 PM
