Exchanging brake booster rod?
I'm thinking of changing my clinkage for my brakes and was wondering if anyone knows how to or if it is possible to remove the brake booster rod with out damaging the diaphram so I can either weld onto it or thread it?
I should mention that it it is out of a 84 Capri/mustng.
the pedal side usually is threaded to support easy replacement and adjustment
the master side (on the universals) has (all of mine) an adjustable/replaceable pin.. ,the replaceable cause the drum vs disk requires a different volume of fluid which changes the piston size (length)
Sam
The pedal side on this one has a round hole to receive a bolt/pin from the actual pedal linkage but with this I have an extra moveable connection(because of the required extra length need on the 55) which is what I'm trying to get rid of. I'm thinking that this booster is not adjustable being OEM for the 84 Capri/Mustang.
filthy6
11-23-2016 11:28 PM
Rusty_S
10-01-2016 11:34 AM
1949 School Bus
02-07-2016 11:13 AM
guitarplayer97
03-23-2015 09:59 PM
1977 crew
29
09-29-2007 09:42 PM
