ZF5 broken tailhousing / tranny mount fix; permanently - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Reload this Page >
Old 06-03-2011, 05:45 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.
Pictures by side2002 - Photobucket
permanent fix to the dreaded zf5 trans mount ears.
i bought a ZF for close to nothin. . .the guy i bought it from broke the ears off, fixed it for a bit via welding, broke them off again and threw his hands up. . .his loss my gain. its pretty common for these ears to break, especially if motor mounts begin to get weak. its evident that its a design flaw. . .ill be usin it primarily for 4wheelin so i wanted it as stout as possible. i ground off the ole ears and ground the surface true and flat. i used a solid block of aluminum 1"x1.5"x8", then cut out two pieces of 1/4" plate to fit around the tail for extra support. i think the block would have held (especially with the support of the center "rib" on the tail itself), but i didnt want any trouble. i spent 15 bucks on material. . .i see people complaining all over the net about this but ive seen no attempts besides just welding the ears back together (stupid idea). theyre just cell phone pics but they do the trick. i dont think i can post pics so photobucket it is. enjoy.
broken zf5 transmission mount zf5 ears zf5 tailhousing zf5 fix
Old 03-09-2015, 05:11 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is online now
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
I would like the see the pics of it completed
Old 03-09-2015, 05:15 PM
'89F2urd's Avatar
'89F2urd
is the photobucket not working? all I did was drill and tap it for the stock mount bolts.
Old 03-09-2015, 05:28 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
ponykilr has a good reputation on FTE.ponykilr has a good reputation on FTE.
Excellent fix! Thanks for not being afraid to dive in a just do it.
Old 03-09-2015, 05:30 PM
Diesel_Brad
I see the piece welded in, but I don't see the new holes drilled taped thru the weld
Old 03-09-2015, 05:33 PM
'89F2urd's Avatar
'89F2urd
here she is. as old and crusty as this thread, but its sustained massive abuse.
Old 03-09-2015, 05:36 PM
Diesel_Brad
Is it tapped or is there a nut on the backside?
Old 03-09-2015, 05:41 PM
'89F2urd's Avatar
'89F2urd
tapped + 4 letters
Old 03-09-2015, 05:45 PM
bashby's Avatar
bashby
bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I had one welded today. Just one ear was broken. The guy who welded it said to be real careful when tapping it since the tap will put stress on the weld. We agreed it would be better to through bolt it with a nut and washer.
Old 03-09-2015, 05:47 PM
'89F2urd's Avatar
'89F2urd
maybe welding the ear back on through bolting would be better...but then again its still not very strong regardless. theyre crispy like tortilla chips.
if I ever had any trouble I just planned to through bolt, but its held fine.
Old 03-09-2015, 06:09 PM
bashby's Avatar
bashby
bashby is offline
Yeah that repair looks stronger than original.
jbrown9709
10-21-2017 10:07 PM
green_95
04-09-2017 10:27 PM
mikie2084
1999 to 2016 Super Duty
08-05-2016 09:34 AM
SuperABen
05-30-2016 09:04 PM
86fu50
05-25-2007 10:49 PM
Quick Reply: ZF5 broken tailhousing / tranny mount fix; permanently
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
