I have tried everything, still no start!!
Hey guys, I have a 1997f350 powerstroke with 150,000 miles on. i was on my way home from work and the truck died. i new the fuel pump was on the way out so i replaced that. and then still nothing. I put three different scanners on it and all three of them would not connect. i flashed the computer and the scanner was able to connect. but yet again. still no start. all of the pressures are good. all of the fuses are good. the GPR is working . The IDM is working. all of the injectors are firing. I cleaned up some grounds and wiring that was chaffing. if anyone has had any problems like this. Please any information would be EXTREMELY helpful. Thanks everyone.
-Tyler
-Tyler
i had the computer totally re written back to stock. the truck was acting as if it was completly brain dead. so that lead me to believe that the computer was not functioning correctly. after the "flash" i was able to see into my computer again with the scanner. before that all of the scanners i trired could not access anything. they wouldnt even connect. i cannot remember all of the specifics but i know the bater voltage was good. dont know the duty cycle. and i can check the other two in the morning.
No codes is the P1111 which is fine. Unplugging the ICP should set codes after you try and start. Then replug it. I suggested that as a means to see if you are able to read codes. It will also default the pcm to limp mode and run at a set default ICP value. If it runs with the ICP unplugged then your ICP could be faulty.
Chris has some good Q's and I am more intrested in the smoke Q than the others at this early stage.
Looks like I should add this too!:
WELCOME TO FTE!!!
Save these links!:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
http://pages.prodigy.net/stevebaz/_i...az/index3.html
1996 Bronco/F-Series Workshop Manual
97-15A 7.3L DI Turbo Workshop Manual
and run your VIN through this link to see what your truck was built with: Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder
see you around!
WELCOME TO FTE!!!
Save these links!:
see you around!
