summers here and my a/c isnt working right
Check the white vacuum line that runs insde the cab. It should be on the passenger side, underneath the hood. You will see like a a little vacumm modulator, that is attached with the white vac line, very far corner on the pass. side underneath hood. See if that white vac line is brittle. Sorry no picture's to show you, but very easy to find.
Hope this helps.
Hope this helps.
