What do you wish Ford would have done to the Bronco before ending production?
Kinda like the 302... fine power plant for a pony car but make it lug around a bunch of weight and it revs its little heads off and is left with little to show for it but an empty tank.
I will say this... what the hell would you all have to do with your Broncos if Ford had done all of that right out of the box? You'd be sitting here with NOTHING to plot and plan for swaps and so-called "improvements" if they had. The Bronco got every option that every F-150 got save a second fuel cell. And what more could you expect considering the Bronco was never intended to be anything bigger or stronger than a 1/2 ton truck. To make one 3/4 or 1-ton would be to make a different model. YOu never had an F-150 with 3/4 or 1-ton underpinnings because there was an F-250 and F-350 for that.
I'll say it again... If Ford had reconsidered its move to drop Bronco production, or at the very least the nameplate, that would have been my preference.
The "city" fuel is up closer to cinci. They have to use a higher refined type of gas and it costs more as well. This was part of the deal to end the e-checks in northern kentucky. The county I live in didn't have the e-check therefore no need to sell the "good stuff" lol. The diesel fuel on the other hand is the same nation wide. It is all now 15ppm sulfur for all types (#1 and #2). But in the winter it gets cold enough here that they sell "winter" fuel. That is a mix of 1&2 to lower the gel piont of the fuel. But right now that is out of circulation. That winter fuel does cut down on mileage tho.
#28
#29
