I went and did it
#992
Word, oil is pristine.
On the way home from work noticed the temp was up just a hair. Not bad at all but it did bump up a hair. Parked it at home and was throwing the ball with my dog, looked over at it and it was puking a bit of something out the over flow. Took the cap off and found this.
All you can do is keep a good attitude.
Soon as I get a couple days it'll be haulin' again.
#994
#995
#996
Crap! That's a shame. Glad you could see clear to still have a reasonably good attitude about it.
I just had a brand new Felpro head gasket that didn't last 500 miles on my 400 and all I heard was good about them beforehand.
Hope that's all that's wrong with yours. We'll be waiting for the good news about your truck once you get it running in a couple of days.
#997
Three brands to never buy for you truck unless it's a last resort. Those are Fram unless it's a paper air filter, Fel-pro, and A1-Cardone.
#1001
#1003
If you hear 5 guys saying they suck that sounds like a lot. But there are 250 or so guys on this forum pretty much all the time. And I'm sure there are plenty of FPs out there doing just fine.
That being said, I have heard a lot of bad stuff from guys even before they knew I used FelPros. For instance WW asked if they were FPs before I said they were. So with the amount of folks having bad experiences with them you can add it up for yourself.
Also, I haven't taken it apart yet so I really don't know a thing until I do.
I do know that I will be buying the best I can in the future.
#1004
As far as Fram goes my beef is with there oil filters. They have a hot glued carboard bottom on the filter element. I've cut two apart and the carboard bottom was separated. In effect not filtering anymore. Fram is trash!!
For A-1 Cardone there rebuilds seem to be now seals and slap some paint on them. I went through three saginaw pumps and one pencil pump. They all whined no mater the bleeding etc. A1-Cardone used to be a quality rebuilder, now junk.
#1005
Remember there are lots of folks going through this forum.
