clutch adjustment
Old Jun 1, 2011 | 08:58 PM
low 66's Avatar
low 66
clutch adjustment
Anyone tell me how to adjust my clutch on my 66 it is a 352fe three speed
Old Jun 1, 2011 | 09:53 PM
99hosss's Avatar
99hosss
hey partner i'll give it a shot- there is an adjusting threaded piece right at your clutch fork which dissapears into your tranny housing . back off on the lock nut on one end , then with a wrench, start turning the adjuster one way or another to get your desired result. then lock the nut back. hope this is what you needed, it took me all nite to write also check all other rods\levers\ pedal brackets for wear or wierd things. Mine had a nail bent thru the rod holding it on to the down rod.
psmith0803
Large Truck
Jul 19, 2012 12:19 AM
cornking
Dec 7, 2011 07:43 PM
low 66
Jun 21, 2011 10:14 PM
low 66
May 2, 2011 07:42 PM
pockets
Aug 19, 2010 11:34 AM
