June-July-August 2011 Junk Yard Wishlist
I need a 1981 ford bronco seat bracket and a bracket for a side mirror. I also need some ideas for and open element air intake.
June, 2011 Junk Yard Wishlist
This was a neat idea, thanks again to whoever suggested this!
Last month's will be unstuck and will fade away, I guess I could probably close it.
Post your wants & needs here, even if they were on last month's list; there's enough chatter on the old one it gets hard to know if somebody is still needing a part or not without reading through the entire thing.
Have to ask you guys to adhere to an FTE guideline I wasn't aware of but has been talked about amongst the mods & admins recently....
==> Please don't post prices <==
It's fine if we want to give/sell things to each other but we can't be running a Flea Market or Auction House here, that doesn't go over well with the admins. Thanks!
NW Ohio/S. Michigan list...
Could use a dash pad (red, black) for an '80-'86 F100. Front seat as well (red-black - or buckets that'd fit) Plastic grill for the same. Cardboard glove box insert. A couple of the red-centered chrome hub covers for the factory wagon-wheels?
OH - and a breaker-point distributor with all the workin's for the 240/300 6cyl.
Thanks if anyone spots any of these within reasonable driving distance of 43402!
Front upper fender molding, there are at least three in the part catalog that run horizontally down the length of the fender, and at least two more that go around the wheel opening.
Tailgate letters, again, be more specific. Some years had an aluminum panel that had F O R D cenetered on it, and others had FORD in the lower RH corner embedded in a red, reflector-like plastic.
Pictures are great, and for what year truck are you looking for these things.
I actually found the "D" last night. It was under the seat. I yanked the seat out to pull the carpet and there it was. Guess my Grandpa thought he might reinstall it someday. It's already been reinstalled.
As for the trim, this is the curved trim piece that follows the wheel arch at the body reveal about 4" from the edge of the fender. This is for my '83 F-250. Mine is broken, missing the front 8" or so. Pics in my "Garage".
Thanks.
Thanks.
Astro & I are chatting about this via PM, but I think the '82 and '83 trim is identical - at least the piece he's talking about, the lower, curved one. I got to that opinion by looking at my '82 from the same angle from which he took a picture of his '83. But, does anyone know for sure?
I do know that the '81 & '82 trim is diff because I put my '82 next to Dad's '81. The '81 has true wheel-lip trim whereas the '82 has trim a few inches above the lip.
Anyone have a set of dog dish hubcaps for an F-250? I'm looking for the ones that are shallow in the front and deep dish in the rear to fit over the full floater rear.
Look like this below...
I still need a set of spider and side gears out of a 8.8 LS diff. Anything from 87 to 2000, 31 spline axles, long tab clutches.
My spiders have lost a few legs (teeth)...
