'88 ranger transmisssion
Did you check the fluid level with the transmission all warmed up?
I think a C4 is the model available then, and the A4LD was a bit later. If the shift indicator has an O selection, it would be an A4LD, but if it has D 2 1, it is a C4.
You can use the VIN decoder available on the site to check.
If it has 'morning sickness', and won't do anything until it is warmed up, you likely need work done, such as new internal servo and clutch seals. If it is intermittent, it could just be fluid level.
tom
tom
