2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Power window noise?!?
Old 08-31-2008, 08:38 AM
amstel78's Avatar
amstel78
amstel78 is offline
When I took delivery of my 08 Expy, there was a small ding in the driver door which the dealer took care of via the services of a PDR guy. Anyway, I've just noticed that whenever I roll my window down now, there is a soft intermittent grinding or rubbing noise. This only happens when I roll the window down; going up is fine. Apart from that, the window operates normally. I was wondering how to take the door panel off to see what could be causing the problem? I'm assuming that in the process of removing the dent, the PDR guy may have bent something in the power window roller mechanism. I'm hoping that it may be something I can remedy myself without having to go to the dealership. Any advice or instruction on how to proceed?
Old 09-02-2008, 10:32 AM
berry1234's Avatar
berry1234
berry1234 is offline
I had a new motor put in the rear passenger door and I had the same grinding. I popped the door panel. Found the installed left the speaker wires in the path of the window. I moved the wires back to there spot, loaded the tracks up with lithium grease and it's super quiet now.
The tracks have no grease from the factory, and maybe they were designed that way, but they need them. PM me with your email and I will send you the door removal .pdfs from the manual.
Old 09-02-2008, 10:38 AM
amstel78's Avatar
amstel78
amstel78 is offline
Thanks for the info. I'll PM you my email address.
OK.. can't seem to find a way to PM you so here's my email: amstel78 at gmail dot com
Old 09-12-2008, 03:51 PM
berry1234's Avatar
berry1234
amstel78, any luck with this?
Old 06-23-2011, 10:13 AM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
Hey Berry,
Would you be able to send me those PDF's on the door removal. Both passenger and driver side windows are now squeaking. How difficult was it to remove the panel?
I tried sending you a PM but you've hit your quota! lol
Thanks.
Old 06-23-2011, 12:32 PM
berry1234's Avatar
berry1234
Originally Posted by hjsimpson
Hey Berry,
Thanks.
Yeah, PM me your email, I cleared out the PM box.
Old 07-05-2011, 09:21 AM
hjsimpson's Avatar
hjsimpson
Berry,
Thank you for the info and that tidbit about the clip near the tweeter was key, otherwise it was too easy.
Upon investigation looks as though my Expedition is suffering the frayed cable syndrome(the lower one). The cable to too far gone to add some silicone to it so I'm going to have to replace the regulator. I think what has happened is that the Expedition badge adhesive has been separating from the outside door panel letting in moisture through the alignment holes. I think I might replace the badge adhesive and use some silicone to caulk the holes.
Does anyone know how difficult it is to replace the regulator?
Also is the speaker mount part of the regulator? From Tasca it looks as though it is.
Can anyone provide me some tips or advise on a DIY replacement?
I looked online for a Haynes manual but the last edition for the Expedition was 2003+ I'm hoping not much has changed.
thanks!
Old 08-23-2011, 06:48 PM
dgruhlke's Avatar
dgruhlke
dgruhlke is offline
Window Noise
Any chance you could send to me as well?
Old 08-24-2011, 02:48 PM
berry1234's Avatar
berry1234
send me a pm with your email add. and I will see if I can find it.
Nothing Special
33
03-26-2022 03:16 PM
annaleigh
05-06-2016 05:51 AM
tomtoc
2009 - 2014 F150
01-28-2016 07:50 AM
kw5413
6.4L Power Stroke Diesel
07-06-2009 07:26 PM
Quick Reply: Power window noise?!?
