No cluster lights
Old May 31, 2011 | 10:39 PM
Diesel 724's Avatar
Diesel 724
No cluster lights
Tonight my cluster green lights quit working. When i cycle the key all the other things light up like SES and W2S ect... my highbeam icon lights up and turn signals.... I looked over my under dash fuses and they appear to be in good shape. Anyone ever have this happen or have any ideas?
Old May 31, 2011 | 10:43 PM
robs01f250's Avatar
robs01f250
I hate to sound negative but they are turned up to the brightest that they can go right?? Not turned down dim? Do your running lights work??
Old May 31, 2011 | 10:55 PM
Diesel 724's Avatar
Diesel 724
Yes sir, i spun the wheel from down to up numerous times and its got nothing. if i turn it up the whole way the dome light comes on still. I believe my running lights work, my head lights do.
Old Jun 1, 2011 | 08:30 AM
Diesel 724's Avatar
Diesel 724
Today ill test them all with the beeper on my multi meter. It never seems to be something easy... My truck is falling apart..
Old Jun 1, 2011 | 09:10 AM
Diesel 724's Avatar
Diesel 724
I believe i found it, #8 fuse under the hood. its a 20 i went all the way up to a 30 and when i turn the lights on it immedietly blows the fuse...
Old Jun 1, 2011 | 09:44 AM
robs01f250's Avatar
robs01f250
That is a bad thing to do to put a larger fuse in place...but its a good thing that it blew it. You have a direct short in the hot wire that runs to the cluster lights. You will need to trace the wiring to see where the short is. I would start at the back of the fuse and trace it from there to the headlight switch/dimmer and then up to the cluster. Hopefully it will be easy to find.
Good Luck!!
Old Jun 1, 2011 | 09:46 AM
Diesel 724's Avatar
Diesel 724
Sounds like a project for a whole nother day. It just sucks i cant see my speed at night! Its never something stupid that goes...
Old Jun 1, 2011 | 08:53 PM
Diesel 724's Avatar
Diesel 724
My tail lights dont work either but my brake lights do.
Buyerz
Mar 2, 2014 02:35 PM
xmontex4
Nov 7, 2013 03:20 PM
rockcrawler_101
Jul 4, 2011 10:31 PM
bigblockford_390
Apr 27, 2009 11:25 AM
dragonz118
Escape & Escape Hybrid
Aug 23, 2007 09:26 PM
