Truck has a miss till motor gets to tempature?
07-06-2011, 07:39 PM
on
the truck starts fine but has a miss till it gets to operating temp 110000 miles new fuel pump 3 new injectors within the last 4000 miles Thanks
07-06-2011, 07:55 PM
Sounds like you may have stiction. Stiction is build up in the injectors.
Rev-x is highly used and reccomended. Some use 1 bottle, some use 2 and it cleans out the build up. if you use 15w-40 diesl oil, switching to any 5w-40 diese oil will also help the engine.
Do you have any codes?
How often do you chage your oil? Do you use racor or motorcraft filters?
07-06-2011, 07:57 PM
Quote:
Originally Posted by
smokersteve
Dammit, you beat me to it. I'm getting slower in my old age.
07-06-2011, 08:01 PM
tex25025
SCORE!
07-06-2011, 08:03 PM
1950t, rev-x will not only clean out the injectors, it will clean the entire oil system, very good
Some even report better turbo operation.
07-06-2011, 08:04 PM
on
Motorcraft filters oil change oil change 7500 Thanks
07-06-2011, 08:08 PM
good! Try and keep the oil changes under 7,000 miles.
07-06-2011, 08:13 PM
Also what about fuel in the area; you go to one station or swap up? 4000 miles is still relative close in mileage that it could have been bad fuel and those injectors held on as long as they could, but just gave out.
07-06-2011, 08:18 PM
on
07-06-2011, 08:35 PM
on
if you were having the same problem with 39,000 on a set of injectors, would you try this stuff first? i'm getting a P0278 contribution cyl 6.
07-06-2011, 08:42 PM
6speed_whistler
Stiction can build up no matter the mileage. It is usually a reflection on fuel quality and/or driving habits.
07-06-2011, 09:00 PM
stiction is the oil, not the fuel? Isnt stiction a reflection of age and or frequency of oil changes.
07-06-2011, 09:03 PM
smokersteve
Dammit, I was reading an EGR issue, I got my threads confused.
I need a vacation. I'm going to crawl back in the cave I came from.
07-06-2011, 09:12 PM
tex25025
haha!
redeem your self by answering this. im login off
6speed_whistler
drh1175
EcoBoost (all engine sizes)
05-08-2011 11:11 PM
DennisA (IL)
Modular V8 (4.6L, 5.4L)
08-13-2010 01:53 PM
Brown Falcon
35
06-02-2010 11:56 AM
Crabby144
04-15-2010 02:16 PM
cougnutta
1997-2006 Expedition & Navigator
03-01-2010 09:48 PM
bad ,
f350 ,
miss ,
misses ,
operating ,
p0278 ,
pump ,
temps ,
till ,
truck ,
water
