Mobile Delvac Extended Life Coolant
I'm sure others with more direct knowledge about this will chime in, but if it is Cat-approved I would see no difference between this and the other coolants being touted around here. That's what specs are for, to let us know when a product meets the same standards as another.
Jut my $.02....
Jut my $.02....
Valvoline.com > Products > Antifreeze Radiator Products > Antifreeze > Zerex® Extended Life Antifreeze / Coolant and you can get the Restore products from your local Cummins parts dealer.
pop
Ok. Thanks for the info. I know about the EC-1 rating. I just wasn't sure about the 50/50 mix. I do have a Napa near home. I was just wondering about the Mobile since it is the same oil I use. The 50/50 mix seemed a little cheaper per gallon than the Zerex but Im not sure what the concentrate would cost. Thanks for the info
I got some stuff from checker auto called Final Charge cat ec-1 rated
It good up to 600,000miles but needs to have an additive at 300,000mi
It also had a hour rating for changes
like 23.00 a gallon full strengh
seams like it was a couple bucks cheaper a gallon than ford gold I got last year
I will leave it in as long as the oil cooler holds spec temp spread and the coolant filters look ok
fresh oil cooler and Final Charge all new at the same time
will see if this new coolant cat ec-1 rated does any justice to our oil cooler problem
