anyone replace these on a highboy?
Old 05-31-2011, 05:28 AM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
hey i need to replace the rubber bushing and sleeve on my front leaf springs where the bolt connects to the shackle. see pic below. anyone ever replace these? what was needed to do it and where can i get these replacements? thanks for any help
Old 05-31-2011, 07:33 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C7TZ-5348-A .. Front Spring & Shackle Bushing-3 per side / Obsolete
(1) Front spring-front bushing / (1) Front spring-rear bushing / (1) One shackle bushing.
"Highboy" applications: 1967/72 F250 4WD / 1973/77 F250 4WD with 6 leaf spring w/o extra leaf.
MILLER OBSOLETE PARTS in Binghamton NY has 5 = 607-722-5371.
GRIESEL MOTOR CO. in Okarche OK has 6 = 405-263-7242.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
PARTS INTERNATIONAL in Farmers Branch TX has 11 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 17 = 800-543-4959.
Old 05-31-2011, 12:08 PM
crazed87bronco
thanks numberdummy do i have to get all 3 bushings if i only need the shackle one? alsi=o how hard is it to replace them? any special tools needed
Old 05-31-2011, 02:34 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Try JBG, i think they may have them.
Old 05-31-2011, 11:18 PM
orich's Avatar
orich
orich is offline
You our in for big job. The first time, I replace mind was 1978 put in OEM. They lasted pretty good for having a camper on it all the time for many yrs. They were not ez as they our pressed in. I then replaced the rear about 6 yrs ago and the fronts last yrs but I've learned a few tricks. Got more tools to make it easier. Buy a metal/wood whole saw cutter the heavy duty one just large enough to fix into bushing to cut the rubber out of them. Yes you'll need a hand drill too. Then, I used a saws all to cut the steel inner shells of the bushing that left in there. And air chisel helps too. Or you can cut them out with a cutting torch if you have a setup. I then cleaned the bushing eyes with a small wire wheel with a drill. Then I then replaced them with the black poly bushing. Yes they do make a little noise like most poly bushing. But if you sand and rough up the part that goes in the eye and apply lots of grease that comes with them. By sanding the inner poly part give them some pores for the grease to holed and settle into them helps keep them quiet. You do get a little harder ride over OEM bushing.. A hell of a lot easier to in stall to.. my 2cents
orich
Old 05-31-2011, 11:19 PM
jhooch's Avatar
jhooch
jhooch is offline
My tool of choice would be a heavy duty air chisel.
Old 05-31-2011, 11:29 PM
NumberDummy
Get the quantity you need, if just the shackle bushings: 2. I just passed the info along that all three bushings in the front leafs are the same.
Old 05-31-2011, 11:48 PM
crazed87bronco
Thanks for the help guys orich where did you get the poly bushings at? I was thinking is need to either burn or chisel them out numberdummy I only need to replace the ones that are in the picture 1 one each side I got SD springs with bushings just need to replace these and ill be good if I got the ones you listed the part # for I'd get 3 of them in a set? I didn't know they were the same bushings used as what's in the leaf spring eyes
Old 06-01-2011, 12:11 AM
NumberDummy
C7TZ-5348-A bushings / You can buy 1 or all 48, as these were sold individually, not as a set.
I listed the original applications per side, takes 3 of these same puppies.
One at the front of the front spring, one at the rear of the front spring and one in the shackle.
Since you've installed Stupor Duty springs, all you need are two for the shackle.
Old 12-15-2013, 11:19 AM
jecsd1's Avatar
jecsd1
jecsd1 is offline
I know this is a really old thread but I'm about to replace the same bushings on my 77. Is grinding the rivets off then reinstalling with new bolts the only way to get access to them?
I have access to a press so installation should be manageable I just don't want to grind off factory rivets if there's a way to install new bushings while in the truck.
Thanks
Old 12-15-2013, 02:09 PM
crazed87bronco
Thanks
You can change them while still in the frame. Just depends how rusty your shackle hangers are. I took mine out because I was going to try using SD springs and there shackle mount but ended re using my stock ones. You can try punching out the old bushings if that don't work use a torch and burn them out and use a air hammer and punch if they are going to give you trouble this is what I ended up having to do installing was easy I used a press but a big c clamp will work if they are still installed in the frame.
Old 12-15-2013, 03:34 PM
jecsd1's Avatar
jecsd1
jecsd1 is offline
I appreciate the response. The steel is in decent shape but the bushings are toast. I'll try your suggestions.
Thanks Again!
Old 12-16-2013, 01:02 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I always try using a hole saw 1st to get the rubber and inner sleeve out. A hole saw as close to the size of the rubber's O.D. as possible. This leaves the metal outer sleeve still in there though. This comes in handy if you are going to use poly bushings which reuse this outer sleeve.
Old 12-18-2013, 05:29 PM
crazed87bronco
You know Jeff I can't believe I've never tried that method. I'll try it next time. no idea how I didn't think of that being a common tool. I'd sure hate if that catches learned that when I used a hole saw to cut my core support for my Intercooler to go through.
Old 12-18-2013, 06:31 PM
orich's Avatar
orich
orich is offline
Aw 2x on the hole saw setup wish, I'd had one back in 1978 when first did them all..
orich
Quick Reply: anyone replace these on a highboy?
