Cannot figure out this brake noise
for a while now I have a strange noise coming from the front tires, every time I use the brake going down a hill, I hear a clicking sound. It sounds similar to the transmission clicking sound when you put it in park. I have had it checked twice and the ford dealer says there is nothing wrong. What do I do? Thanks
By any chance have you changed front brake pads or rotors lately? I've heard that clicking sound after changing out pads with slotted rotors on one of my cars. I'd take the tire off and look at the rotor/caliper to make sure all is correct. Check the slide pins to make sure that they are free and lubricated. I just did new slide pins/hardware on my truck and what a difference in brake feel.
I'd bet (based on your answer to new pads) that the noise is of no importance...the noise will diminish as the pads seat to the rotors.
There are a set (two) pins which allow the caliper to "float" when the brakes are applied and released. Here is a writeup on maintaining the slide pins (thanks Guzzle). Entire slide pin replacement, retaining springs (wrapped with sound deadening material), new slide mounting bolts, and slide pin rubber boots ran me about $40.
Wes, you would be much better off doing the slide pins yourself...You can do all four wheels in an afternoon, you will know the job is done correctly, you will have the satisfaction of knowing you did it, AND the money you save can be used to buy some good beer . I wish I was down on the Gulf Coast, I'd come over and give you a hand !
