1999 Ford Explorer Sports 2Dr Shuts off after Ignition
Old 05-27-2011, 06:27 PM
HardeepOne's Avatar
HardeepOne
HardeepOne is offline
Hey guys this is my first time posting to this forum but i've been reading a lot of posts here and love the feedback. I'm currently having a little issue with my car, this is a first for her as well. I drive a 1999 Ford Explorer Sports 2DR. I got her with 62K in 2005 and driving her since. She now has 155K and never had a problem with her. When I turn her on, she revs up normally where the RPM needle goes up to about 2 then usually sits at RPM 1, but now she goes from RPM 2 down to 1 then 0 and cuts out. Even when I keep revving it up a little she just cuts out. I thought It may have been the alternator so I bought a used one from the junkyard and installed it myself, but still have the same issue.
I spoke to a friend who's a mechanic and he said to clean the throttle body also there is a little injector/spray/filter thing right above the throttle body, but I cannot remember the name of it. I believe it was ASL/ACL/ALS or something along those letter mixes.
If someone could help by showing me how to clean or replace that little ASL thingy it would be greatly appreciated.
So I took out the trottle body and cleaned it. Took out some gray sensor thing on the top, and cleans it, but it has not done anything to it.
Here is a video of the gauges.
YouTube - ‪1999 Ford Explorer Sports Ignition Shut off.‬‏
Thanks again guys.
Old 05-28-2011, 11:03 PM
scucci's Avatar
scucci
scucci is offline
If it dies when you let go of the throttle, it is your iac(idle air control). Many guys clean them with wd 40, but they are not that expensive at autozone, O'reilly's and other auto parts so I just replace them.
Christof13T
27
09-29-2012 08:31 PM
creeper113
Modular V10 (6.8l)
26
08-23-2012 05:08 PM
hotroddually
21
11-16-2009 11:41 PM
cryptonik420
03-09-2004 01:31 PM
beidle99
07-24-2003 12:34 PM
Quick Reply: 1999 Ford Explorer Sports 2Dr Shuts off after Ignition
