Excursion HPOP Reservoir Gasket 7.3L
You SHOULD have the one with the screen.
The one without is for the '96 - '99.5 7.3L diesels and they are not interchangeable, and since there is no E99 Excursion, you SHOULD be safe in ordering the one with the screen.
Stewart
Edit: It's a bit of work, but if you wanted to make absolutely sure, you can pull yours.
Edit 2: Why do you want a new gasket?
Stewart
Stewart
Stewart
Thanks Stewart, I was thinking the same thoughts. I already ordered and received the one with the mesh filter, but wasnt sure it was correct after seeing the other part# and want to get everything to the mech all at once - went ahead and ordered the one without the gasket too about 10 minutes ago - so now I should be covered, just didn't want to wait an extra day or two for this one to arrive
Need a new HPOP and some sites say to order the HPOP reservoir gasket as well for the swap.
Why do you think you need a new HPOP?
How did you (or someone else, mechanic, etc) determine you need a new HPOP?
Stewart
What do you think? Hpop seems logical (mech said he thought it would be that even before switching out all that stuff). Only other thing I would think would be injectors?
If that last sentence is harsh, maybe I misread what you were trying to convey when you said the mechanic "guessed."
What kind of testing have you done to ascertain your HPOP is bad?
Unless you're so well off financially that you don't care about throwing money at your truck to try and fix it, I humbly (but strongly) urge you to post about your problem in the 7.3L forum.
When you do, please try to answer the questions posted. In your previous thread (the starting issues thread) you never answered my questions and you didn't tell us how you determined your Ex had been modified to use a GPR and not the GPCM.
HPOP's rarely are the problem, yet mechanics will point to them as being the source, charging a ton of money to customers who don't need a new HPOP.
Stewart
Thanks Stewart I will post in the 7.3 section. As far as the GPR goes, the truck was definitely changed to the relays instead of the GPCM. The module is nowhere in sight, and the who relays are definitely there . Wired up a switch to manually work the glow plugs on and off (also tied into the IAH. I do get the codes for the GPCM module no communication with the PCM. But the glow plugs do work, and the truck starts fine - so I think we solved the cold starts. This seems like an entirely different issue. Appreciate the input.
...the truck was definitely changed to the relays instead of the GPCM. The module is nowhere in sight, and the two relays are definitely there . Wired up a switch to manually work the glow plugs on and off (also tied into the IAH. I do get the codes for the GPCM module no communication with the PCM. But the glow plugs do work
Please do post in the 7.3L forum. If it is your HPOP (rare) we can help you determine if it is, or if it's something else.
Stewart
thanks, hopefully get it figured out. would hate to install an HPOP and still have the issue
its over there Stewart: https://www.ford-trucks.com/forums/1...uld-it-be.html
Stewart
The only way to test a HPOP is with a mechanical gauge. If you have auto egenuity you can take the IPR and ICP readings, but they aren't a true measurement of the HPOP PSI Does it smoke when it shakes and stumbles? What color is the smoke if it does? Did you buy the cheap ICP sensor and pig tail?
427 fordman
08-18-2010 05:34 PM
strokin'_tatsch
12-14-2008 10:15 PM
Steve
01-18-2004 06:20 PM
