1978 - 1996 Big Bronco
Transfer Case 1356
Old May 26, 2011 | 08:06 AM
dld63's Avatar
dld63
Transfer Case 1356
Have an 87 Bronco. case shifts into neutral and won't come out. Changed the motor with same results. 4X4 light stays on and Low Range flashes ( Code? )
Is the ECM the main one.Going to put a code reader on. Hoping its not the harness.
Old May 26, 2011 | 10:44 AM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. We will do our best to get you the most accurate information we can.
Unfortunately, the EEC-IV computer does not monitor the t-case shift electronics. There is a separate shift control module behind the passenger side kick panel. Chances are that the problem is low fluid in the case.
Old May 26, 2011 | 01:29 PM
dld63's Avatar
dld63
Auto parts said there was no listing. I will check though. Did not check everything yet, just got it towed back last night. Gave up on the parking lot thing
Old May 28, 2011 | 07:19 PM
NWBronco's Avatar
NWBronco
The shift motor turns a flat blade that moves the shifter. Do as stated and check the fluid. Then drop the motor and grab a pair of needle nose pliers and see if you can shift the case manually.
Old May 31, 2011 | 06:38 AM
dld63's Avatar
dld63
Turns out the module was bad. Changed the motor anyway as we did not like the way it sounded. May have been part of the problem. But thanks to all.
kynnhoj
Jun 1, 2015 08:36 PM
smittys5xs
Apr 22, 2015 09:44 AM
crisk
Apr 17, 2015 11:39 AM
fourty03
Jan 2, 2015 09:14 AM
Andy Sullivan
Feb 15, 2014 04:52 PM
