"Gold" interior pieces; seat cover, door panels with cup handles and armrest pads, dash pad and headliner.
Explorer bed rails.
Explorer mirrors (well made)
Explorer stripe kits (I'm partial to Yellow)
Aftermarket - how about a bolt on twin piston brake kit with hubs for separate rotors by Wilwood or similar.
A 5 speed conversion kit for Tremec TKO or T5. Maybe even a hydraulic clutch option.
Reason: Changed the color name to the original
Dennis Carpenter reproduces the bed rails. They're $395.00.
Page 103 in the catalog P/N D3TZ-9932230-C for the shortbed and D3TZ-9932230-B for the longbed.
I put a TKO-500 behind the FE in my '70 F100 long bed. Contact Paul or Bruce at Modern Driveline and they'll help you out with all the parts (Trans, trans mount, clutch package, pilot bushing, speedo gear, shifter arm and boot, reverse light pigtail). It'll require a shortened input shaft to fit a stock FE bell. My trans crossmember only had to be moved back by one inch.
The mechanical clutch linkage works just like OEM.
Yes sir, I've called them and talked to them. Thing is we're wanting to use an existing transmission, a Tremec 3550, for the application. It's just not as versatile as the TKO. Thanks for letting me know about the crossmember. I needed that info.
Thanks for the info Mike! I didn't have a Dennis Carpenter catalog. Ordered one this morning!
LMC has a wiring kit W/relays super easy to install also u can upgrade headlights just need to make the holes in the buckets a bit larger die grinder does the job.
