Shifter Rail Problem on M5r2
Old May 22, 2011 | 05:16 PM
WT8413's Avatar
WT8413
I have a '93 F150 with the M5R2. I'm doing my first transmission rebuild. So far, I have everything disassembled, cleaned, and ready to order my replacement parts; however, I have ran into one last problem. I have to replace both shifter forks. I have removed the shifter fork off of the center rail, but I cannot get the other shifter fork off. I have taken out all the pins and I have tried hammering/tapping the shifter rail to where I can pull the remaining shifter fork out. The problem is, I can only tap it like 1/4". It seems to be jammed or something. After some research, I have concluded that one of the interlock pins may be jammed up or something, but I really have no clue. If anyone has had this issue or has any suggestions, I would greatly appreciate it. I feel like I am right there but have hit a wall. Thanks ahead of time for any responses.
DPDISXR4Ti
46
Jan 1, 2022 09:08 PM
FrozenOcean_xXx
Mar 11, 2015 12:03 PM
TelefunkenU47
May 24, 2011 10:28 AM
keepnthepeace
Sep 29, 2007 10:14 AM
