Another no cruize / horn question...But THIS is odd.
Are you certain that the clock spring is not the issue? My F150 developed the no-cruise. no-horn, airbag light problem. And it was the clock spring. I replaced it it and all is fine now.
No offense but did you read any of the thread? . Sorry no pun-intended. I dont have a clockspring. Ive already identified the issue. I need help identifying the wiring for cruise, from my harness off the column to the factory cruise harness. My truck does have factory cruize but it seems the column was once replcaed.
OK, I don't mind the joking or even getting beaten up in forums, but I still don't understand how the horn and cruise control buttons would work without a clock spring in this particular truck which should be pretty much like mine except for the heavy duty parts. I don't think the 3/4 ton and 1 ton trucks have special HD horn or cruise control although I might be wrong. Anyways, the OP still has the same problem and I still don't know how it can work without a clock spring.
I believe 1ton trucks didnt have to have an airbag, since my truck does not have an airbag a simpler copper plate with three sliding contacts was sufficiant. The siding plate is no different than my horn hookup in my 1969 torino Here is the side with out the wheel on. The steering wheel, I dont have a pic, but has a 3 ring coper plate that corresponds to the three pins in the pic. So with the horn and the cruise buttons only three leads come from the steering wheel.
#28
I take it you have a cruise servo under the hood? I was thinking about that this week but didnt have a chance to post. Was wondering if you had a swapped-in cruise-equipped steering column into a truck that didnt actually have cruise, but if you have the servo under the hood then its just a matter of connecting two wires, you just have to figure out which two. Look at the plug on your servo, see if any of those wire colors match the 2 you have left over in your gray square plug. if you find a match, i'd confirm them by checking continuity, if they are to the servo, i think they are the 2 wires you need for the column, since the horn was on that plug. Then just connect each of your column cruise wires to a grey plug wire, if cruise still doesnt work, reverse them. i dont think it would hurt anything to have them reversed to test, but i'm not sure. The only other thing you can do is study some schematics and figure out why your wires are different colors. this helped me 1983 Ford Bronco Diagrams picture | SuperMotors.net
Shouldnt there be a cruise on/off light on the dash?
#29
