What 9 inch came in a 69 4WD?
on
NumberDummy decoded the VIN on my vehicle a couple of years ago. I just looked at the dif and it is missing the tag, and the casting numbers I gather are not that informative (C5AW 4668 A in any case).
I have a buddy with an original Ford Traction lock, but I think I need to know how many splines are on my 9 inch, and what type it is. Is it possible from the year and VIN to make an educated guess before we go to the trouble of pulling it apart?
F11 = F100 4WD
Y = 360 2V
R = San Jose CA Assembly Plant
D85409 = 1969.
131" Wheelbase
K = Empire Green
F110 = F100 4WD / 5600 lbs. GVWR
C481: C4 = Pastel Parchment Corinthian Vinyl & Pastel Parchment Kiwi Pattern Vinyl // 81 = 81B Custom Cab
A = New Process 435 4 Speed Manual Transmission
08 = Ford 9" / 3.50-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
5600 lbs. GrossVehicleWeightRating
179 Net HP @ 4000 RPM
B7 = Ford Motor Company of Canada-Pacific Zone
By the way, I love that 179 Net HP @ 4000 RPM.
F11 = F100 4WD
Y = 360 2V
D85409 = 1969.
131" Wheelbase
K = Empire Green
Hay Paul this is likey a number dummy thing but I think Ford used 28 spline rears until '73 in F100's I wouldn't sign my name in blood on that but that sounds familiar to me. too bad you cant find the tag I think if there is a "L" in place of a "." would be a locker there again not 100% on that. and I think the front would be a dana 44.....
on
Cory,
Based both on what NumberDummy decoded, and the way it drives, I am positive it does not have a locker rear end.
I think the locker that my neighbor has is for a 31 spline, and I suspect you are right, I just want to confirm what was standard before I turn it down. I don't want to take it apart to confirm that it won't work.
Paul.
Paul.
on
Brown 79 - the honest answer is I'd rather avoid all of that as it is a bit of work and I'd rather spend the time on several other things, plus I have aluminum spacers and wheels, and they both need to be re-torqued after taking them off. Yes, that does suggest a certain amount of laziness!
I am pretty sure it is the original rear end, so if I can confirm that 69s came with a 28 spline I'll go in a different direction.
Gembone
575
03-28-2023 10:10 PM
mongo75
09-27-2011 09:17 AM
Reneej
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
07-08-2011 08:05 PM
