Power Window Conversion Complete
Old Mar 24, 2003 | 12:39 AM
charlez's Avatar
charlez
Cool Power Window Conversion Complete
Just thought I'd give you guys a few pointers if you want to try this. I have conveted from manual to electric windows. The hardest part of the whole thing was gathering all the parts. (I have lots left over, check the classifieds).
Here is what I got for parts. I picked up some door panels off ebay($$$$$$), and then went to the salvage yard and purchased 2 complete doors. I picked out a couple beat up doors and got the pair for $150.
Installation tips.....
Well, it's not too difficult, I just drilled out the rivets and transfered the regulators. Now putting them in is a different story. I first tried to use rivets. The problem is most stores only carry 3/16 rivets and even if they had 1/4, the tool is kind of pricey. I attempted to use the 3/16 ones with washers but the regulator was still loose. What worked really good (should have tried this first) is to just use 1/4' bolts.
I had to run all new wires, but that way it matches everything else.
Well, I now have power windows and LOVE them.
Old Mar 24, 2003 | 10:09 AM
brown 4x4's Avatar
brown 4x4
Sounds like a good conversion. Where did you run your wires to for power?
Old Mar 25, 2003 | 12:43 AM
charlez's Avatar
charlez
I just ran power directly to the battery (fused). This way they are powered all the time, which I like.
Old Mar 25, 2003 | 10:49 PM
steve83's Avatar
steve83
There is a wire coming off the fuse block on all trucks for the PW system, and another for the PL/PM. You can tie into that for stock function.
SVTDriver97
'80-'86 HOWTO's
Jun 23, 2016 08:18 PM
Spktyr
Mar 17, 2013 12:46 AM
DanielC
Aerostar
Jan 16, 2011 01:51 AM
mfp4073
1983 - 2012 Ranger & B-Series
13
Jun 21, 2009 02:53 AM
rebocardo
Apr 24, 2004 01:29 PM
