2006 6.0 stumble
#61
Got the alternator back in and now shes charging 14.4 !!
checked the batteries
- passenger side = 14.4
- driver side = 14.2
She said that (2) diodes were shot
upgraded the bearings - rectifier
replaced everything else with new.
$110
going to order a smaller pulley to boost the output a little bit more at idle.
$110
#62
#63
#65
#70
#72
code again today:
had it checked ....
Dang EGR excessive pressure (AGAIN)
Now I am wondering if I purchased a defective EGR valve (or) the IAT2 sensor is bad eventhough I cleaned the gunk out of it.
gonna pull the IAT2 sensor back out tomorrow and see if some more gunk got in it.
I have a hankering to throw the old (cleaned) EGR valve back in it to see if it makes any difference also.
had it checked ....
#73
what is the exact code its throwing
is it still the P0402
P0402 C* Exhaust Gas Recirculation Flow Excessive Detected EGR Valve Position does not match desired, limits based on
engine speed / load.
EGR Valve stuck or sticking - EGR Valve Position Sensor Bias - EP
Sensor bias
have you tried to clean the EBP sensor and tube yet
Sensor bias
#74
Sensor bias
Sensor bias
Didn't get the exact code (Running late for work) but I did read where it said something like
Excessive High Pressure
note:
A collection of things I have replaced so you guys don't have read the whole thread.
- new EGR (Delphi Unit)
- new EBP sensor / cleaned the tube and the hole where the tube
attaches
- new ICP sensor
- removed and cleaned the turbo
- new fuel filters
- new oil filter
- removed and cleaned IAT2 sensor
#75
