Fuel Line Removal Tool Success
Got the pressure line off quickly when switching tools. I used a tool purchased from Advance Auto made by AutoCraft, 3/8" fuel filter line tool, # AC504, $15.
Came to the conclusion the plastic set & the cheap multi size scisor-like set I have wasn't lifting the fingers high enough to clear the barb. The AutoCraft unit is thicker (thicker tubing wall) and lifts the fingers above the barb.
This was confirmed when comparing the tools mounted on the metal hanger/sender unit pipe. Literally, it came off in 5 seconds.
The AC504 looks to be a good casting or machined part and is anodized in a gold color.
Might try this as a last resort.
Tried again 3 days ago to get mine off and still couldnt.. I have the plastic tool and metal scissor tool. Neither works...
Im just taking it to the ford dealership if this doesn't work. Tried getting it off like 5 times within the year and keep giving up. On my old F150 it came off no problem.
Yeah i might have to try that tool. Its like 3 times the prices of the cheap scissor tools but if it works, its worth it to me.
I think the PO tried to just pull the line off and F%#$ my filter line connection. I'm almost afraid to really work and get it off, as with my luck the line is toast.
smcox1
62
02-19-2017 08:01 AM
bullsmack
1999 to 2016 Super Duty
11-16-2015 10:50 AM
rufushusky
09-21-2015 08:14 PM
Jus2shy
2009 - 2014 F150
01-12-2012 06:35 AM
FLAUSA
07-08-2005 08:08 AM
