1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Blend Door Actuator Problem Is there a fuse or relay 2006 f350
Old 05-10-2011, 10:02 AM
Jawbreaker's Avatar
Jawbreaker
Jawbreaker is offline
The air auto climate control would only blow very hot air thru the defrost when it should blow cold air out the front vents. Removed blend door acturator motor behind the glove box and it would not rotate the shaft when out and hooked to power. Ordered a new one, but it too wont turn under power. I am looking for a fuse or relay, or other reason why. I can't believe the new one is bad too. In the manual nothing looks like the blend door actuator fuse or relay. I havent checked the power with a volt meter yet. The vacuum solenoid moves with different commands for the A/C. believe it is an electrical problem.Any help???
Old 05-10-2011, 11:48 AM
jh818's Avatar
jh818
jh818 is offline
Maybe a vacuum leak. Check your lines.
The following users liked this post:
Old 09-06-2012, 10:17 PM
BigRodsAuto's Avatar
BigRodsAuto
BigRodsAuto is offline
Hvac autuator Heater blend door 2004 f150
Don't get in a rush to judgement like I did I have just went thru 3 days ripping the dash out to find the blend door is good no voltage to the actuator I supplied temporary voltage and it worked.I went to my local Ford and they let me use a wiring schematic,I traced the actuator to fuse no.5 it also supplies power for guess what else was not working?Back up lights.Put in a fuse heater/air works as it should until I put truck in reverse,it blew the fuse again and now the heater/air is not working again.I now know there is a short.
Old 09-07-2012, 05:43 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
The system is run off of vacuum. When there is insufficient vacuum to run the climate control system, the system reverts to blowing air through the defroster vents.
Find your vacuum leak. Do you have ESOF 4 wheel drive?
Old 09-11-2012, 11:07 AM
BigRodsAuto
Blend door
That is very possible.
Old 04-18-2017, 02:39 AM
AntonioCm1983's Avatar
AntonioCm1983
AntonioCm1983 is offline
same problem
is fuse 5 same for 2005 ford excursion with climate control i have the v10 i have 2 brand new blend door actuators and neither of them work which is telling me there not getting voltage nore power so does fuse 5 does the same thing on my year
Old 04-18-2017, 08:22 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
No. That particular user had a half ton which has a completely different wiring setup.
The BDA does not have its own fuse, it gets its power from the EATC.
Old 04-18-2017, 08:29 AM
AntonioCm1983
Update
are you saying the blend door actuator harness gets its power from the climate control head unit itself
Old 04-18-2017, 10:29 AM
projectSHO89
The previous statement stands on its own and is relevant to the specific vehicle and option under discussion (05 Excursion with EATC).
Old 04-18-2017, 10:37 AM
AntonioCm1983
I asked that because I was trying to make sure I understood your first statement correctly which I'm not sure did all I asked if it what I said from what I understood was correct or not
Old 01-28-2021, 10:34 AM
Dbeam7's Avatar
Dbeam7
Dbeam7 is offline
long shot, but my 06 f250 is doing the exact same thing? You ever get it figured out? I saw where the power comes from the climate control unit, although I’m not positive if that’s the case. But I’ve got one on the way. I believe it is faulty either way because it won’t display, or will hang up
Daniel Paul Pursch
2017+ Super Duty
01-07-2021 11:59 PM
Studawg
06-10-2020 06:32 PM
88 Rustbucket
21
06-26-2017 07:32 PM
Jawbreaker
05-13-2011 12:25 PM
Shakina Glory
1983 - 2012 Ranger & B-Series
01-03-2004 04:43 PM
Quick Reply: Blend Door Actuator Problem Is there a fuse or relay 2006 f350
