Missing and sputtering at 55-65 mph low rpm
I just bought it a couple months ago, 05 F350 6.0 95k on it, all stock. All updates done. It is starting to sputter and miss about 1300 rpm 5th gear, just cruising... I can get on and off it and it runs fine, sputters a lot more before it is warm in all gears at the same rpm. As it gets warm it just does it in 5th gear. Any ides? Plugged in my buddies Edge Cts, no codes, temps all look fine. Oil and fuel filters done at the Ford dealer a couple thousand miles ago, I have put about 8 thousand on it.
While cruising down the highway, mine would do a "woof" as my wife called it. It would "woof" a puff of black smoke. I checked everything I could. If I kicked the truck down to 5th and raised the RPM's it wouldn't do it. Then it got worse while towing my TT. But only do it at 1700 rpm in 6th.
Stopped in at Ford dealer, grabbed a new EGR valve. Changed it out at the campground, problem went away. Hasn't been back.
If this is what is happening to you, then that is what I did for mine.
What do you mean the FICM checked out????????????
Haveing 48Volts is a Great Sign But NOT the whole storey with the FICM.
Did you run a Buzz Test on the FICM???
You can also try a Ballon Test on injectors here is a few links I saved
REPEAT INJECTOR DIAGNOSTIC TIPS
http://www.forddoctorsdts.com/techni...orTechTips.pdf
COMPRESSION BUBBLE TEST
DTS Articles - Compression Bubble Test
BALLON TEST
DTS Articles - The Balloon Test
If you decide to pull injectors I might have a trick up my sleave to test out the truck I know it works on really Bad Injectors but ones that just starting to go IDK
Kyle Whittington
02-17-2020 11:36 AM
screaminford
1978 - 1996 Big Bronco
16
08-15-2016 10:39 AM
U771663
21
07-07-2016 07:25 AM
U771663
07-06-2016 10:25 PM
TangoAplha
04-19-2013 03:05 PM
