Steering Column Bearing?
on
The bearings going out are pretty common. The problem I've had trying to replace them is there is no good diagram available of how it goes together. The bearings are really weird looking. The 2-3 times I replaced the bearings they still had some play when I got done and slowly got worse. They went bad in my dads 96 F250 and we took the column to a local salvage yard and they rebuilt it for around $100. 6 months or so later we took another column to them and I think it was $4-$500. They are a PITA!!!
Where can I get these I. We'd the upper set. Whole replacment bearing thing
F3TZ-3517-A .. Upper Steering Column Bearing / Available from Ford.
MSRP: $9.13 // FTE sponsor PARTSGUYED.COM price: $6.58.
F4DZ-3517-A .. Lower Steering Column Bearing / Available from Ford.
MSRP: $8.30 // PARTSGUYED.COM price: $5.98.
These two bearings fit multiple applications too numerous to list.
To see what they are, type the part numbers into Ed's website.
Just got "done" with my ignition actuator and bearing install
Problem is the snap ring only goes to the first slot on the upper steering shaft and my column jiggles around... How do i pull the upper steering column forward to seat it on the rear bearing? I can't get the snap ring onto the 2nd notch?????
Also, how in the F#@* do i get the column tilt spring back in?!?!
75BigBlock
06-01-2017 12:24 AM
Snowseeker
37
05-31-2017 04:48 PM
