I cant get my clutch to where its supposed to
i have a 94 f150 with M5OD trans. just replaced the clutch master cylinder and have bled and bled the system over and over again topping off the resevios in between and my pedal still doesnt feel right and it squeks like theres air in the lines no matter how many times i bleed. any help would be GREATFULLY appreciated.
Bleeding a Concentric Hydraulic Clutch Set-up .: Articles Click on this link and read steps 1 and 4. Also check that your pedal bushings are good and check the firewall for flexing/cracks.
I'm not trying to be a smartass, but is it possible that the rubber seal is still in the master cylinder? I'm only asking cause a friend of mine did this and messed with his truck for a few days till i had time to stop and look at it. When i finally made it over to look at it I checked fluid first only to realize the rubber had stuck around the top and not in the cap and he filled it up instead of the resevoir itself. just an idea.
yea i figured it out after days of tryin to bleed it nothing hell i even bought a hand vaccuum pump and tried that and nothin so just for the hell of it i turned the truck on and did it while it was running and i had it done in less than 5 mins turns out theres a vaccuum line even for the manual trans and wen i cracked the bleeder all the air bubbles spurted out. ha every where i looked said to not have it running and all this garbage ha guess they were wrong
