400 water pump/damper replacement questions
Need some help.In the process of replacing water pump and damper in my 1978 F250 with 400 engine.I have both removed and I'm wondering about resealing the plate between them and the engine.Best way to remove crank seal?Is there a gasket for the plate?Will I need to replace part of the oil pan gasket?
I'm also having problems finding a replacment damper,this is the part number on one I'm replacing #D7TE-BA
Thanks
Thanks
Last MSRP: $181.11 // Dealer net cost: $108.67.
Applications: 1977/78 F100/350 & 1978 Bronco 351M/400 w/a manual transmission.
No Ford Dealer or obsolete parts vendor has any.
D6AZ-6020-A (replaced DOAZ-6020-A) .. Cover Plate Gasket / Obsolete
Applications: 1970/74 Passenger Car 351C / 1971/79 Passenger Car 400 / 1975/79 Passenger Car 351M / 1977/79 F100/350 351M/400 / 1978/82 Bronco 351M/400 / 1980/82 F150/350 & Econoline 351M/400.
Autoparts stores sell a kit that includes the seal, cover plate gasket, and the front section of the oil pan gasket...that the cover plate fits into.
Damper Doctor rebuilds harmonic balancers with new rubber, and they allow a value for your old one. They also do drive shaft center bearing supports and motor mounts.
Damper Doctor Online
Damper Doctor Online: Casting Number Interchange
Looks like a D7TE-BA would be their # FOR3512
Damper Doctor Online: FORD 351-400 C.I.
Also some info here on numbers
http://grantorinosport.org/BubbaF250/parts/parts04.html
Plate has to seal against block, to prevent oil leaks and to seal coolant passeges for water pump. Two dowel pins locate the plate, there is a gasket between the plate and block as well as one between the water pump and plate. I use weatherstrip adhesive on these.
Seal is simply removed from plate and new one installed with plate removed. Do not bend the plate. New ones are available in steel or maybe aluminum, etc.
http://books.google.com/books?id=teV...ration&f=false
djed
05-15-2017 02:25 PM
Redworks
06-30-2015 11:48 AM
Effin-Yeti
09-26-2014 11:39 PM
bigb609
11-21-2011 05:35 AM
