broken rear leafs
Old May 7, 2011 | 11:10 AM
2classics's Avatar
2classics
broken rear leafs
need rear leaf springs. Good place to get them, and/or upgrades. keep near stock height. Sorry if this has been covered, doing a search now.
Old May 7, 2011 | 12:22 PM
KrautBurner's Avatar
KrautBurner
LMC Truck http://www.lmctruck.com/icatalog/fc/full.aspx?Page=118
NPD? http://npd.dirxion.com/WebProject.as...uk10flx&from=2
junkyard....
Old May 7, 2011 | 12:29 PM
2classics's Avatar
2classics
need rears
looked at lmc. $310 a side only 2400lb a side cap.
Anyone use bronco graveyard springs? Cheap and 2700lbs. says for bronco/f150/f250?!?
little nervous
Old May 7, 2011 | 12:33 PM
KrautBurner
Originally Posted by 2classics
need rears
little nervous
Bronco Graveyard should be good too
Old May 7, 2011 | 12:36 PM
2classics's Avatar
2classics
maybe give them a call monday.
Old May 7, 2011 | 05:26 PM
jtrux's Avatar
jtrux
I talked to jbg about those springs but the thing thatade me hold off on them was shipping, he said it was gonna be like 90 bux for shipping to tx. Sounds too high to me.
Old May 7, 2011 | 05:57 PM
MikeS29's Avatar
MikeS29
OOPs!
Old May 7, 2011 | 05:58 PM
MikeS29's Avatar
MikeS29
Originally Posted by KrautBurner
Good call on LMC, but FYI, page 118 is for Front Leaf Springs for a 4x4...try page 116:
http://www.lmctruck.com/icatalog/fc/full.aspx?Page=116
Old May 7, 2011 | 06:04 PM
jtrux's Avatar
jtrux
Holy cow, is that 300 each?
Old May 7, 2011 | 06:08 PM
MikeS29's Avatar
MikeS29
Looks like $259 each if you get the F150 springs, $299 each for the F100. Plus hangers, bushings, bolts, etc. etc. etc. SPENDY!
Old May 7, 2011 | 06:45 PM
2classics's Avatar
2classics
spendy is what I thought. JBG with $90 in shipping is still cheaper. Thing that worries me is the drastic price difference, the description says bronco/f150/f250. However, the weight rating is higher than others(LMC, rock auto). How do they ride?
Old May 7, 2011 | 07:34 PM
jtrux's Avatar
jtrux
The guy at jbg really couldnt tell me much, im still thinking of grtting them just hate to spend soo much on shipping.
Old May 7, 2011 | 07:46 PM
77FordDW's Avatar
77FordDW
I've run into the same problem. I have 3 4WD trucks out here with the 3" wide springs. I'm going to make 2 good sets from everything I have and use those till I can afford the bucket full of cash it costs for new ones. >.<
Old May 7, 2011 | 07:53 PM
2classics's Avatar
2classics
I probly will to. Not a DD.
Old May 7, 2011 | 08:02 PM
GLR's Avatar
GLR
Is the main OK? you could just replace the broken leafs. Is there a local spring shop? Check with them.
