Bad news, I gotta pull the flathead....
During my first drive I had a bad vibration I thought was driveline related. Turns out it's engine related....
First problem was the fan is bent, causing most of the vibration. No big deal, find another fan blade.
I also had a lot of valve noise.....so I decided to pull the intake while the generator and fan were out of the way. I wanted to check the lash and see what all the racket was about.
Let's just say the clearances are excessive..... I rebuilt this engine 10-15 years ago and really don't remember the details. I must have been using a paint stick for a feeler gauge though.
So out it comes, might as well check everything while I'm at it. Who knows what else is screwed up.
Kind of a bummer, still haven't really got to drive it...
One of my buddy's has a fresh SBC for sale.....hmmm I wonder????
I hate to hear that the flathead needs rebuilt. I know they can get expensive to work on. Wish there was a flathead for sale (not for very much money) near you that you could use while rebuilding your flathead...but thats like finding a needle in a hay stack.
PS: Its just as easy to drop a SBF in as it is a SBC LOL
I should clarify......My motor IS rebuilt. I just did a half assed job on it years ago. This project wasn't supposed to take 20 years to finish. I will pull the heads, fix the valves, and re-assemble. Shouldn't take more than a couple hours.....right? Right???
I was just kidding about the SBC....once you go FLAT, you never go back!
My F1 came with an unfinished rebuilt 8BA. I pulled the heads off and I found it packed with corn. dang mice. The pistons were stamped STD, and everything looked good except a couple rusty valves and a couple minor veins of rust in a couple of the cylinder walls. Plan is take it apart, go through it, and put it back together. About all I'm in for are new gaskets so far. Hopefully that's all you have to do as well. Good luck!
SBCs are great engines for Chevys. SBFs and BBFs are great engines for Fords. When starting from scratch I have to wonder why folks think the Chevys are a better choice for their old Fords. The production Ford blocks actually have a higher nickel content compared to the Chevys which makes them last much longer....... I'll be quiet now.
Clearances...
It seems to be just the exhaust valves for some reason.....one is really loose. Like 0.038 loose! Others range from .020-.025. Not sure WHY they are so loose. Engine has stock non adjustable lifters......I vaguely remember the valves being too long and grinding the ends on the bench grinder??? LOL, must been all of the paint fumes I was breathin back then....bottom line, this is all my own fault.
BTW, I did a comp test first to make sure the valves weren't sticking open...it turned out fine. All cyls are real close.
I have decided to not pull the motor just the heads, and put some new valves in. The guides are still free, so it should be fairly simple. Fingers crossed.
Thats a fun job to do with the engine in the truck! but probably better I guess.
I was going to say the same thing as Tim. Seems like Up north there you should be able to drive a couple miles and find any number of old farm trucks with flatheads in them.
I'm in Salt Lake and everytime I drive into Idaho I could get sidetracked every couple miles. then there's Montana! Gets even better!
I've got a (supposed rebuilt engine from about 2002) that I don't think has very many miles on it since rebuild and Is going to go in my F6 project. I had driven the donor truck and seemed to run good and good compression but did have a slight tick or valve? noise? not 100% sure but I also plan on pulling intake at least to see whats going on in there?? kinda hoping that I find adjustables if any adjustments are required...
btw when your done with your valve job your welcome to come down here to breathe some more paint fumes! lol I need someone who can paint to spray my F6 I like your paint job
Good luck
Josh
Good luck
Josh
