Radiator question
Radiator question
I just picked up a new radiator. The old one in the truck has 2 hose attachments at the bottom and the drain. The new one has the 2 hose attachments, drain, and 2 other threaded input/outputs. If I didn't already have a tranny cooler, I would assume that those are for that. Any ideas what they are? Is it ok to just leave them open?
Thanks for any input.
Jason
Jason
OTW cooler in the radiator is another transmission cooler in series with the other cooler. I wouldn't think it would hurt anything if you just capped the lines but not 100% sure. Probably be better to run supply line to the radiator cooler then output to the stock trans cooler and back to the transmission or see if you can return it and get the right one. The return line on the transmission is the rear one.
It does not matter which side you use for input or output. On the transmission the front line is supply and rear is return. It might be easier to come off the return line of the stock transmission cooler to the otw rad. cooler and then return to transmission. So you would be going to stock ota cooler then to rad. otw cooler and retuning to transmission. It doesn't matter which cooler you go to first just use whatever is easiest. Also make sure you use some 3/8 inch line that is compatible with oil. Regular fuel hose isn't. I picked up some from a local hydraulic shop.
IIRC the drivers side is the in, and pass side is the out. Like Grant said It prob doesn't matter, but I added the same radiator to my truck. The extra cooler (otw) sure helps keep it cool.
Ford routed the lines go to the radiator first, then to the cooler, and back to the trans incase you decide to do it., but again it prob doesn't matter.
I think mine are the opposite maybe not maybe I should get off my butt and go look.....
