4X4 shifter question!
I see these break all the time. It's not so much the Magnesium but the bolt "gaulds
itself to the bushing where it rubs.
What I do to avoid this is mark a position while on the truck with a marker. This is the position easiest to get a grease gun in there...
THen I take off the 2 bolts from the trans, un do the bracket, and boot up top.
Put it in a vice, carefully. I then heat the NUT that is spot welded to the steel bracket, I usually have soaked it with some penetrating oil. Heat the nut cherry red, then run the flame over the housing quickly. I then start to work loose the bolt, be careful not to snap anything, take your time re heat as needed. When cool, I drill and tap a grease fitting at the mark i made. If you get lucky and save a bushing I put one back in, clean the bolt, and fill with grease.
Every season grease it, or when your down there keeps that expensive lever in one piece.
