Trans plug leak
Old 08-14-2014, 05:36 PM
Liquid_force's Avatar
Liquid_force
Liquid_force is offline
Trans plug leak
'03 Aviator
I changed my trans filter and fluid a few weeks ago. Since then I've been getting a few drops of fluid on the floor every day.
Trans is clean, plug is wet.
Was there supposed to be a gasket or o-ring? I don't recall seeing anything.
I thought I'd add a metal gasket and some teflon on the threads.
Good idea? Bad idea? Other ideas?
Old 08-14-2014, 09:03 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
Rock Auto shows two different types of drain plug gasket. A gasket should be all you need. Teflon tape is for tapered pipe threads. I wouldn't use it. You run the chance that some of it will come off and get in the oil pan or the pickup.
Old 08-15-2014, 04:16 PM
Liquid_force
Put on a nylon gasket and added 1/2-3/4 qt today.
Will be keeping an eye on the garage floor the next few days.
SoCalAngler
37
04-22-2014 08:46 PM
jssblues
1978 - 1996 Big Bronco
02-18-2012 08:39 PM
swirlparanoid
2004 - 2008 F150
09-15-2010 08:06 PM
ecs
04-26-2010 12:04 PM
George D.
04-15-2008 10:42 PM
Quick Reply: Trans plug leak
