I have a '95 f250 with a 460.. I'm looking to upgrade my camshaft to something with a more low end to mid range gain. i've been searching but can't really find anything. what have you guys used? and what's a good cam for my efi 460?
no problem... We answer a lot of engine related questions on the 87-96 forum when really we should probably be redirecting people to the correct engine forum. I know there are plenty of 460 guys on here so stick around long enough and I bet you find what you need.
PS: try searching through google. put "www.ford-trucks.com 460 rebuild" into google and it will probably reveal a couple older threads with good info about cams... Seem like in the last 4-6 months there was a guy going to school for engine building and he had a 460 rebuild thread going. Searching through google works a lot better than using the search on here. putting the ford trucks web site in will bring up FTE forums...
