Holley Indentification
Old May 2, 2011 | 10:18 AM
Big_Dom's Avatar
Big_Dom
Question Holley Indentification
I need to find out if my carb is the 500cfm verison of the Holley 2300 series, or the 350cfm verison. The computer I'm using won't open any pdf files so the holley parts guide won't open and I can't find anything else to help me out. I figured some of you might be able help. LIke Builit 390 or NumberDummy might know but any help is appreciated.
Old May 2, 2011 | 10:22 AM
jredline1984's Avatar
jredline1984
If you wanted to post the number I can check through some of my reference material, otherwise give Holley Tech a call at 270-781-9741. They have excellent support and can give you all the info you need on the carb.
On a side note, its nice to see someone else from Great Falls.
Old May 2, 2011 | 10:31 AM
arctic y block's Avatar
arctic y block
Where ya been Dom? Have not seen ya on the boards lately
Old May 2, 2011 | 04:57 PM
jsutton's Avatar
jsutton
I have the 500 cfm model on my truck and I know the accelerator pump diaphragm on the 500 is 50cc and on the 350 cfm it's only 30cc. You can definitely tell the difference in them by looking at them the 50cc is much deeper. Just my .02
Old May 2, 2011 | 10:57 PM
tbear853's Avatar
tbear853
What is the List # on the front of the air horn?
Old May 3, 2011 | 12:27 AM
Big_Dom's Avatar
Big_Dom
theres 3250 with an oval around it...
Old May 3, 2011 | 09:48 AM
Big_Dom's Avatar
Big_Dom
List number is 4412-5; 0203. Please and thankyou.
Old May 3, 2011 | 10:00 AM
arctic y block
Morning Dom. They should be able to tell ya what ya got with that number. They did with mine and I was able then to get a kit for it.
Old May 4, 2011 | 08:35 AM
jredline1984
Sorry for the delayed response, work has been hectic.
Looks like a list 4412-5 is a 500 cfm carb. Let me know if you need anything else.
Old May 4, 2011 | 11:08 PM
Big_Dom's Avatar
Big_Dom
thank guys. and morning to you arctic. been really busy lately.
Old May 4, 2011 | 11:13 PM
arctic y block
Morning Bud. Ya I used ta be busy, Than I got old
Old May 5, 2011 | 12:39 AM
tbear853's Avatar
tbear853
Yep, 500 cfm.
Holley Performance Products 500 CFM Two Barrel Carburetor 0-4412C
Features
•Manual choke
•50cc accelerator pump
•1 timed (spark) port, 1 full vacuum, & 1 PCV port
•Intended as stock performance replacement for 2-bbl street applications. Also mandated carbs for some oval track racing sanctioning bodies
•Ford A/T kickdown, does not work with A.O.D. transmissions
http://www.holley.com/data/Products/...R7950-7rev.pdf
RileyCarroll
Dec 29, 2019 07:25 PM
oldschool-f150
Sep 3, 2015 11:55 AM
Sdoug76
Oct 16, 2014 08:49 PM
78midnightmudder
Mar 12, 2007 08:41 PM
JARedman
Feb 8, 2006 12:12 PM
