2005 F350 fX4 4wd issues
05-02-2011, 03:21 AM
on
I have an 05 FX4 auto 6.0, my 4wd wont work Ive changed the switch, the box under the dash by the glove compartment and still it wont go into 4wd hi or lo, any suggestions? I switched out the solenoid on the transfer case and it didnt help, if i test the wires going to the solenoid i get absolutely no reading when siwtching the switch..... any suggestions would be great, thanks alot
05-02-2011, 12:35 PM
on
Fuse, relays or wire harness.
05-02-2011, 11:42 PM
on
What fuses and relays would affect this? thanks
05-03-2011, 09:41 AM
on
There is a relay box on the drivers side wheel well that holds two relays. One of them is for engaging 4WD and the other is for disengaging 4WD. As a test you can try swapping them and see if it will engage. Assuming it engages you'll have to swap them again to disengage.
11-02-2011, 09:27 PM
on
If it will go into 4 wheel drive by manual lock check your vacuum in the auto lock system?..
Capt No Slack
2004 - 2008 F150
01-06-2017 07:58 PM
pattece
2004 - 2008 F150
11-14-2013 02:10 PM
mattsautobody442
2004 - 2008 F150
03-03-2013 09:12 AM
bigbubba87
03-06-2012 12:47 PM
maguyver
2004 - 2008 F150
09-26-2008 06:18 PM
2005,
2007,
4wd,
60,
diesel,
f250,
f350,
ford,
fx,
fx4,
pickup,
problems,
proplems,
reports,
truck,
v8,
workshop
