Costco has issues with my lugnuts and stripped them.
Old 05-01-2011, 07:08 PM
Spaceman Spiff's Avatar
Spaceman Spiff
Spaceman Spiff is offline
Hi, my old OEM rim were getting corroded so I decided to put winter tires on them and get new rims for my summer tires. I went with new OEM Ford rims from the dealer but acquired used lug nuts.
The folks at Costco said they used a "21" socket and it would only go over 1/2 of the lug nut and stripped it while the "22" socket was too loose. Anybody else have issue with these lug nuts? Can anyone tell what size of socket these lug nuts use.
Looks like I need to go to Ford and get some new lug nuts. Can someone confirm that the Ford part number for the lugs are: 2L3Z 1120-AA.
The rims themselves were part number 2L3Z 1007-AA.
Attached is a pic of the rims and the lugnuts.
Thanks
Spiff
Old 05-01-2011, 08:31 PM
brokenleg's Avatar
brokenleg
brokenleg is offline
Ive dealt with those kind of lugnuts...........I hate them.................If costco goofed them up, Id make them do right by you....
Old 05-01-2011, 08:51 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
umm... i coulda swore they are 13/16.
Old 05-01-2011, 08:59 PM
jyount's Avatar
jyount
jyount is offline
That is because the part they put the socket on is not the lug nut. That is merely a dressy cover. The nut itself is less than half of the length of it. Like he said though, problem number one is that it isn't metric.
Old 05-01-2011, 09:10 PM
Spaceman Spiff
I take it the socket should completely cover the entire lug nut? It seems like their socket only covered the lugnut about 1/2 of the legnth.
Spiff
Old 05-01-2011, 09:19 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
That's what happens to that style of lug nut when someone uses a shallow socket instead of a deep to remove the nut. The top of the nut deforms, as shown in your picture, and won't allow a proper size deep socket to fit the next time. They then try a larger size deep and strip the nut.
Old 05-01-2011, 09:21 PM
Spaceman Spiff
Thanks. I am guessing that is what happened.
Spiff.
Old 05-01-2011, 09:51 PM
jyount's Avatar
jyount
jyount is offline
Spiff
Yes it goes to the bottom of the nut, not 1/2 way, there is not nut there, just a cover.
Old 05-02-2011, 07:54 AM
Spaceman Spiff
Thanks for the info.
Spiff
Old 05-02-2011, 08:36 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Sounds to me like Costco needs to buy you new lug nuts, not the other way around.
Old 05-02-2011, 08:44 AM
Spaceman Spiff
Costco is buying atleast 4. I may buy the rest so I don't have issues later on.
Spiff
Old 05-02-2011, 09:29 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Spiff
That sounds fair.
V10RP
Modular V10 (6.8l)
11-22-2014 09:33 PM
Leon82
1999 to 2016 Super Duty
07-27-2014 05:42 AM
Bud Mud
04-14-2014 06:44 AM
Bud Mud
04-09-2014 05:54 AM
lance65
08-30-2011 09:45 PM
Quick Reply: Costco has issues with my lugnuts and stripped them.
