7500lb travel trailer dont need weight dist?
As far as a brake controller, this is a MUST. Because it will be aftermarket, it may not be fully integrated, but you can play with the gain enough to make it a smooth ride on the highway and in the city. Spend the $50. If you don't, you will be breaking the law and you'll surely jack knife the first time you lean on the brakes in an emergency situation.
Well it already has a wdh for a f150 on it so i guess that can be made to work. But the trailer will be pulled by several vehicles and i dont want to have to adjust it for each.
The tongue weight is fairly light 6000 empty 7500 max double axle.
How hard is the tbc to instal with a harnes is it just plug in and mojnt on dash?
It would prob need dropped one position as the superduty sits higher! Put the trailer on level land, level the tongue, and measure to the top of where the ball would couple. next get your truck on level ground, and measure the ball height on your wdh. Adjust the ball height too the trialer height. There is more to it, but this will get you in the park! (You can adjust the angle (front and back) of the ball, but I would try it where the angle is set currently). I know there is more too it, but My hitch was setup by the ppl I bought my tt from. So I never messed with it, and dont know a great deal about its workins. Unless the others are usin the same model trucks, at close too the same height, it should be setup for every truck!
As far as the TBC, it is VERY easy. You will get instructions with it when you buy it. On my last one, the RV dealership did it for free since I was already in there for other stuff. Took the guy all of 10 minutes. If your vehicle has a TT pkg on it, you most likely already have a harness under the dash to the right of your steering column. Good luck!
Just wanted to update. I got a tbc and the wdh adjusted by a trailer dealers shop.
Hit the scales and came in at 14,600 and my gcwr is 15000. I had full tank, fuel and fresh water tanks full. 450lbs of passengers/dogs. 100 lbs of canoes. And around 350 lbs of gear in truck bed. I carry all the heavy stuff in the truck becuase the cMper is near gvwr with just the basics.
But 400lbs of remaining capacity is not bad.
It really tows fine i have the manual i just go 1 gear lower than normal. Start in low and almost never use OD except long flats at 60mph which i dont see much. Have a nasty on ramp near me onto a 65mph highway up a decent curved hill that starts from a stop sign. This was something the 2v f150 had problems with. I have to rev it up pretty good but im doing 60+merging vs ~50 the old rig did.
Overall im happy. But single digit mpg in the mountains and low teens elsewhere towing.
Still considering a gear swap at some point
The advice regardng a weight distributing hitch and brake controller is excellent and well intended. Even if legal and safety issues were not in the equation, the proper equipment just makes it so darn much more relaxed when towing.
I will say, if you buy from the dealers I service for, if you come without a properly set up tow vehicle, which includes a brake controller, the unit doesn't leave the lot.
If you shop Craigslist you can find perfectly good used hitches for about a $100 and even cheap brake controllers without the bells and whistles work just fine.
Stay safe and have fun with the trailer!
Steve
Steve
Chris89lx
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
18
03-27-2009 04:12 PM
stu37d
General Automotive Discussion
20
08-11-2007 07:24 AM
