Does the D50 TTB use inner retainers for the wheel joints?
I want to replace my wheel u joints on my D50 TTB and the parts store has joints that are external clip and inner clips. Does anyone know off hand which ones I need? Truck isn't around for me to check.
i think they did yeah.
though i seem to recall reading about trucks from back in the day using the D50's on the extended cabs.
if the D44 uses external clips,this would explain the auto parts store calling for two types i guess.
I know my 1/2ton 44 uses external clips. When i did joints on my 50 i did have an issue with the fancy greasable joint being about 1/32nd" too wide had to go back to the cheapy without the zerk. Both were internal clips
I think you can get a plug for the grease fitting hole that is flush mount screw in design. Then if you really wanted, you could grease it, pull the zerk out and screw in the plug. I have had good luck with the synthetic grease non serviceable joints though, so far.
