Has anyone installed a body lift on a 1997 f150? I was wondering how hard its going to be and if its worth it to have it professionally installed. Thanks
not hard at all, you could do it in a day. basically just unbolt the body raise it up to put in the blocks bolt it back dow. install longer filler neck and gear shift linkage.
