Header Question
Old Apr 26, 2011 | 08:42 PM
dentside302's Avatar
dentside302
Header Question
Does andybody know where I can get a set of headers that will fit a '77 F-150 with a 302 and a side mounted tank?
Old Apr 26, 2011 | 11:05 PM
mark a.'s Avatar
mark a.
I would imagine Summit, Jeggs, etc would have them.
Old Apr 26, 2011 | 11:07 PM
FarmerBill's Avatar
FarmerBill
I'm sure Headman/hooker/flowteck/BBK etc. will work as long as you don't have 4x4.. just my experience is that anything with 4x4 is a C . . . to find headers that fit well. Try Jeggs or summit or your local parts store.
Old Apr 27, 2011 | 06:57 AM
Dags's Avatar
Dags
+1 on that bit.
I am looking for a set to fit a '79 4x4 with a 460 BB here in Australia, and have found 1 set local that the guy wants $1600 aud for. lol
That's not going to happen.
Old Apr 27, 2011 | 08:40 AM
73FOMO's Avatar
73FOMO
You may want to look at the shorty headers for the 5.0 trucks. They have them at Summit for less than $150 bucks, and if you check around on some of the Ford Lightning boards, you can find the stock lightning shorty headers for $50 to $75. You then have the flexiblity in fabricating your connector pipes from the headers to the muffler(s).
Old Apr 27, 2011 | 02:58 PM
FarmerBill's Avatar
FarmerBill
Great idea 73 FOMO , some times i wish i had a 5.0L So much aftermarket support.
Old Apr 27, 2011 | 03:09 PM
dentside302
Thanks for all the info. I forgot to mention that the truck is a manual and it is a two wheel drive. The headers from Hedman say they are only for automatics. I tried Jegs but not Summit.
Old Apr 27, 2011 | 03:18 PM
FarmerBill's Avatar
FarmerBill
hmm not 100% sure but i would tend to think that having an auto would hinder you and that anything would fit a stander transmission. usually anyway. auto's have the wider body's an such.. guess there's the clutch rod/pivot. Just thinking out loud.
Old Apr 27, 2011 | 03:33 PM
73FOMO's Avatar
73FOMO
Yes, and as much as they get dogged on here....I prefer to go with the 5.0 due to that fact. I love the support and parts availability. I am willing to run my stroked 302 against any 351. I knocked down 8.1 sec at 83mph in my last 1/8 run, 4.84 0-60 time, and 1.83 60' time.... according to my datalogger.
Old Apr 27, 2011 | 08:54 PM
dentside302
I checked Summit and the exact same Hedman Headers didn't say that they were auto only, but three other sites say that they are.
Old Apr 27, 2011 | 10:06 PM
shookdaddy's Avatar
shookdaddy
put u a set of big tube shortys on it i had a 75 302 auto w a side mount tank it had duals on it i found a set of bbk shortys at a local pic n pay bolted them on. the exhaust ran from driver side under the bellhousing to the pass side then after the rear crossed back over n came out the driverside so if u can find a good exhaust shop u could even run long tubes but the shortys will do the same thing as long tubes
Old Apr 28, 2011 | 08:23 AM
73FOMO's Avatar
73FOMO
Basically what I did. I welded up a mandrel 2.5" y-pipe to a merge into a single inlet dual outlet magnaflow that splits and comes out the back as duals. Here is a pic of the much improved y-pipe. I currently am using gen1 lightning shorty headers.
https://www.ford-trucks.com/forums/1...st-y-pipe.html
Old Apr 28, 2011 | 08:49 AM
Sleepy445FE's Avatar
Sleepy445FE
Originally Posted by Dags
+1 on that bit.
This made my morning! hahaha $1600?!?! Platinum headers! That's one heck of an import markup.
Old Apr 28, 2011 | 11:19 AM
73FOMO's Avatar
73FOMO
$1,600 Australian Dollars....that's even worse....that is $1,747.20 USD. I guess these are like gold in Australia.
Old Apr 29, 2011 | 08:27 PM
dentside302
Do you happen to know what shortys they were?
