2004 f250 wipers and fluid not working Done the usual stuff checked the fuses in the cab and the 15amp fuse is good and the 30 amp fuse is good. Is there something under the hood i should look at?
will check with a meter tonight. I just did a quick check by visual and moving the fuses to see if they worked. Any link to a procedure for checking the switch on the column?
