08 Expy a/c stops working from time to time
Ok, the truck did it again and I was home to check it out. The driverside air is blowing out HOT air, but yet the passenger side is blowing out the COLD air like normal. I wouldn't even know where to start looking to fix this. It doesn't do it all the time so by the time we would ge it to a dealer it would be working fine. Any suggestions?
Do you have manual climate control or dual - diff temp each side?
If manual, I cannot offer an explanation.
If dual, seems the blend door for the drivers side is not working all the time.
The blend door is responsible for making the temperature you select by blending heat and AC. If its closed or not working on either side you get the symptoms you're experiencing
Dashes are a little different in the F150 vs the Expedition.
I dont find much on replacing one in a full size ford, but here's a nice write up for an Explorer that should give you an idea of what you could be in for.
I dont think its a terribly expensive part, but labor is the killer
How To: Replace Blend Door Actuator in 3rd Gen Ex. - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Riceburnerfb1
06-25-2016 05:34 PM
