The camper thread! Pulling, using, equipment, maintenance!
#302
#303
#304
Got some new E's for my rig. Got the genset tuned in. Two more weeks until we head out.
#305
I'll sanitize and freshen the fresh water tank/system.
With the hot water heater STILL bypassed...I'll take 1/4 cup of bleach for each 10 gallons of capacity in the fresh tank...so on my 40 gallon tank...I'll use a cup of bleach...
Dump that in and then fill the tank to mix it up.
Then I'll run all the faucets to pull the bleach/water mix into the lines...you will smell a light bleach smell.
I'll let that sit for about an hour...
Then I'll run the faucets to drain the tank (filling the grey tank to to "sanitize" and "deodorize" it too before dumping).
I'll then refill fresh tank and run the faucets to "flush" the lines with fresh water.
Doing this once more with just fresh water...this gives a good rinse to the plumbing and tank.
Last step...I take a quart of distilled white vinegar and dump that into the tank and fill the tank to "deodorize" that from the bleach smell...I'll let that sit for a little bit before running the faucets to complete the sanitize/deodorize/flush steps I take.
That keeps my fresh system clean and fresh smelling and hopefully free from bacteria...
It takes me a couple of hours to complete this process...
Good luck!
Joe.
#306
Every year when I de-winterize the camper from the pink stuff in her veins...
Good luck!
Joe.
Good luck!
Joe.
Just pulled in and unhooked everything. After some quick searching on the net I found exactly like you mentioned Joe and did exactly that. But I quick pulled my tank out and filled it with the mix and let it sit for 2 hours. I didn't have time to pull the pressure washer out but I used a good nozzle on the hose to wash out the tank best I could after emptying the mix and it looked pretty darn good. Then I put the tank back in and put a little more mix in to run all the lines. My water heater system was completely dried out and closed off for years now so I didn't have to worry about that. I let it sit in the lines for an hour and then let the water run for an additional 20-30 minutes. The lines all cleaned up great and looked nice and clear. While the pump was rattling away I was digging around and zip tying lines and wrapping them with rubber where they rubbed or was tied to something. Helped with the noise some. Is there a quieter style pump for suitable for low pressure camper use? Ever since I was a kid I disliked the loudness of camper water pumps. Also what can you do between trips to keep the tank from greening up again?
Rest of the trip went like normal. Only other weird thing was my X showing 10.6mpg on the way up and 12mpg on the way back. It always got 14.5-14.6 on this trip.
#307
Nice looking TT and Excursion!
I looked up the specs of your TT and they are very close to mine. what trailer prep have you done to the X to pull that? My 2005 X has upgraded shocks and a Prodigy brake controller only. i have been wondering if I need any upgrades before our first camping trip (550 miles roundtrip)
#308
My family just got back earlier this week from a 7 state 2100 mile camping trip, with zero issues with the camper or Excursion. I cant imagine doing this trip with a smaller vehicle, We had my family of 6 for half the trip and we added grandma for one 730 mile leg of the trip.
Here are a few things I learned.
1. I averaged 10.2 mpg for the trip. My PSD has 7,000 miles on it, so I am hoping for a slight improvement in mileage when its fully broke in.
2. 834 miles in one day is a bit to long for my crew to handle. (kids aged 12, 11, 3, and 1)
3. Before of long trip out west in 2014 to visit some national parks I will upgrade to the Equalizer hitch.
4. The Excursion is really comfortable out on the road!!
5. I would like to slightly quite down my 4" exhaust, expecially over 2500 rpm
thanks for all the tips in this thread!
I added a few shots to my garage.
1. Camping on Oscaloosa Island, FL
2. Dropping off the camper at my sisters for a few days in GA
Ford Truck Enthusiasts Forums - Bigdaddybus's Album: Garage - Big Daddy's Bus - Picture
#309
My X is my Scout's favorite vehicle for travel. I usually tow the trailer as so we're never left at the mercy of an underpowered vehicle .
I've had 2 offers by folks in the Troop to buy my X as my son is out and I'm just helping the Troop out now & then. Perhaps in another year, I'll move to a 250. Its kinda hard to put an ATV in the bed of the X.
#311
Got one of this & it meets the need, but I'm getting to the point where I want to take the ATV along with us, but it ain't going to work with a popup. I no longer need 8 seats either... the utility of a pickup bed is becoming more & more appealing.
That all said, its buy a toy hauler/camper or a newer truck. The pop up works great for us, so the truck might just be easier. Regardless, need another year to work up the cash.
#312
#314
#315
